Re: Hey Allan!
Posted by Nat 2 on January 18, 2006 at 05:28:47 from (64.80.108.53):
In Reply to: Re: Hey Allan! posted by Allan in NE on January 18, 2006 at 03:27:50:
So if I understand it, the wheels aren't turning as far as they should? They'll turn farther, but can't because of the tierod linkages, right?
Ah, that's easy if you don't mind a little cutting and welding. There are two ways to go about it:
1. Shorten the arms at the spindles.
2. Lengthen the arm at the steering box.
Frankly, I would go with #2. If the tractor's done any loader work, it's been broke there before anyway and probably needs to be reinforced. Plus, it's only one cut and weld versus two. On top of that, it's hidden under the tractor where nobody can see the crappy job you did :)
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
