560 D Was gonna fix the Torque
Posted by Ronald on January 18, 2006 at 17:57:17 from (205.188.116.133):
I bought a 560 D last summer and it had alot of small problems. I never used it and just fixed a little bit here and there. Yesterday I got it in the garage and was going to split it to fix the torque. I got it split and saw a tooth missing on the constant mesh gear, before I was done I had a bare housing and a bad Constant mesh gear, bull gear and pinion and ring gear and pinion. Now 450 dollars later I can put it back together this weekend, and get back to the torque(Which is new to me)
