Re: 686 brake parts diaghram
Posted by mAPLERIDGE on January 18, 2006 at 19:29:25 from (24.198.52.183):
In Reply to: 686 brake parts diaghram posted by tn terry t on January 18, 2006 at 16:52:01:
Take the adjusting nut off. Take the bolts out of the outer cover (five or six). Pull the cover off and you will get a good idea what you are in for. There are usually spacers beneath the cover you can remove if you are out of adjustment and your disks still have life. The brake is a dry unit and you will see a disk which you can remove. Behind it is the brake unit which you can pry out. It is two steel plates held together with 3 springs between which there are 3 balls, all of which can wear or break. Next is the last disk. If your pedal is going to the floor and you are out of adjustment, you either need to remove the spacers or need a new set of discs.
