Re: Putting 291 Gas Engine in 460? Tractor Vet or
Posted by K.B.-826 on January 18, 2006 at 21:28:19 from (68.115.111.89):
In Reply to: Putting 291 Gas Engine in 460? Tractor Vet or othe posted by migraine on January 18, 2006 at 19:42:23:
It will be a bolt-in deal. You'll need to use the 460 front cover, and possibly the rear plate. I know the 656, 666, and 686 used a smaller flywheel and clutch than a 560 or a 706, ect., but I don't know if they were the same size as a 460. Dosen't matter though, because your 460 flywheel will bolt up. Might have to enlarge the exhaust pipe hole in the hood, if you're using the 666 manifold, which I recommend.
