Re: Need ideas for C263 crank fix.
Posted by Tim...Ok on January 19, 2006 at 03:59:12 from (66.137.61.93):
In Reply to: Need ideas for C263 crank fix. posted by Kelly C on January 18, 2006 at 20:24:10:
Dang Kelly,thats pretty steep for a crank grind..last one I had done 2 years ago run me $70,might try to find a machinist who actually grinds his own cranks,most don't...sounds like the middleman is adding a substantial markup to it..
Tim
