Re: Live Hydraulics on M
Posted by captaink on January 19, 2006 at 09:05:57 from (66.115.214.56):
In Reply to: Live Hydraulics on M posted by F-Dean on January 19, 2006 at 06:17:22:
In MHO the BEST way (also expensive way) is to go with the live pump between the distributor and the timing gear. There was a change made in 1950 to improve the timing gear on the camshaft, some of the older ones with these live pumps had gear problems. However, I’ve had one on my 1950 M, and the gear broke in 1969 but no problems since. It seems to me there was a change in the front cover too. If you have a loader on the tractor with a supply tank, plumb it directly into the pump and keep the belly pump as a back up. If you don’t have a loader on it, take the belly pump out, get a tank made (or build it yourself) and put it where the belly pump was. On this tank you can use ¾ inch fittings for the input line to the pump. You can plumb the return as you see fit. This setup gives you maximum reservoir capacity and maximum supply to the pump. (You can gut the belly pump and use it for a reservoir but you will be limited to the suction side by the size of the drain hole in the belly pump.) Mount your self a spool valve somewhere and you are ready to go. I wish I could give you a cost amount, but all I can say is it won't be cheap.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
