Re: super a engine questions
Posted by El Toro on January 19, 2006 at 09:16:49 from (152.163.100.65):
In Reply to: super a engine questions posted by werowance on January 19, 2006 at 07:36:54:
I would find another auto machine shop. One that doesn't know the difference between std bearings and .002" undersize I would stay away from.
You should take the crankshaft to a reputable
auto machine shop and have it measured. Probably needs at least a polishing. They can supply new bearings too.
Rod torque is 40-45 ft-lbs with nuts using cotter pins and 43-49 ft-lbs with self-locking nuts.
Mains require 75 ft-lbs. I would use a bearing clearance of .001"-.0015". Hal
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
