Re: 400 T/A questions
Posted by DEWAYNE UTRUP on January 19, 2006 at 09:26:17 from (216.227.55.31):
In Reply to: 400 T/A questions posted by super99 on January 18, 2006 at 15:22:10:
Chris,
Are you tapping on the end of the shaft on the outside of the case? This is where you need to tap and it should come right out. Your note made it sound like you are tapping on the inner cast fork which will not move since it is held in position by the throwout bearing.
good luck,
DeWayne
