F-20 variable speed governor questions
Posted by JohnG(TX) on January 19, 2006 at 13:05:41 from (216.136.20.34):
I am planning on changing over my Regular to the variable speed governor like the ones found on the late F-20's. I have the field change-over parts that go on the outside of the engine, but was wondering what else I need to look for. I have heard there are differences with the governor itself, maybe lighter fly-weight springs? Also, is there a spring somewhere to keep the throttle linkage pressed against the governor control so the governor and open and close the throttle as it pleases? Normally, I think the governor can only close the throttle, not open it.
JG
