Re: Value of Farmall 460
Posted by migraine on January 20, 2006 at 21:45:24 from (71.197.231.212):
In Reply to: Value of Farmall 460 posted by Jeff Jackson on January 20, 2006 at 16:24:19:
Most of the 460's like you describe are in the 2400-2800 dollar range. I would test the TA on low side with heavy braking or starting out from stop in 4th or 5th gear. Many of these old gals were not kept properly adjusted and need work in there. Pretty expensive fix if you have to hire it all done. About 50 horse is all you can expect from the stock motor but may have been changed to 560 specs over the years. These were built from 1958 to 1963. Feel free to ask any other questions. Fast hitch is a plus and power adjust rear rims where an option. Hope this helps. Migraine
