Re: ih 3588
Posted by scotc on January 21, 2006 at 07:16:56 from (65.220.16.62):
In Reply to: ih 3588 posted by tomtill on January 20, 2006 at 21:04:11:
We had a 3788. They are nicer in hot weather because the engine is way out front, there's a cab firewall and fuel tank in between, and the fan blows out the grill not in through the grill. Just don't go at the fuel pump wanting a bigger tractor. IF the rubber coupling at the engine doesn't give the pressure plate probably will. I know this because I lifted the front of ours with my allis 7580, carried it home, and backed it into the shed, due to it not having any power anywhere but the electrical system.
