Re: Removing the C263 from 706
Posted by Short Bolt on January 21, 2006 at 10:55:01 from (69.21.20.75):
In Reply to: Removing the C263 from 706 posted by Kelly C on January 21, 2006 at 09:35:27:
Kelly: You should have 10 bolts block to clutch housing. All face in toward clutch housing except for top 2 which are above the starter they screw in from back side. While your in the clutch housing you might just as well replace the PTO drive shaft. and put the new seals in also.. Also if the 706 dose not have a TA there is a small brass wear band on the trans input shaft check it also.. Once you open up a 706 its like opening Pandoras box you will find things that need fixed or replaced. Been there done that 1 706 is enough. By the way I hope you marked you power steering hoses that came off the top of the valve on the clutch housing? If you cross them you will dump all the little pieces of junk thats trapped back into the steering system. To replace your throw out bearing you will need to remove snap keeper on right side and drive the clutch shaft to the left. if you replace the PTO drive or seals. If you replace the pto drive, and have a old trans input shaft you and weld the 2 togather and make a clutch tool out of them. Hope this helps
Home
| Forums
Today's Featured Article -
Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
