Re: Glow Plug voltage
Posted by Scout1 on January 22, 2006 at 11:37:49 from (207.162.169.152):
In Reply to: Re: Glow Plug voltage posted by The Red Barron on January 16, 2005 at 18:56:22:
The B414 is in series like christmas tree lights.
When one goes out they all quit working until you track down the burnt one. In a nutshell battery to switch to resistor to #4 gp heavy copper wire run from #4 to #1 with a ground from #1 to water pump.(positive ground system).
Now I have a question. I replaced the starter for one with the solonoid on it and took the ford style switch off, I also put an alternator with a built in regulator on it, and took off old regulator. It had a one 12volt battery system on it when I purchased it, so if I use the basic glow plug set up already on there I will be running a positive to the #4 gp and a positive ground from the #1gp(causing resistor melt down). How do I ground the system from a negative ground standpoint with this set up?
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
