Re: Anyone else this happing to ?
Posted by williamf on January 22, 2006 at 12:03:23 from (66.82.9.90):
In Reply to: Anyone else this happing to ? posted by Randy-IA on January 22, 2006 at 10:19:22:
More likely it's the settings on your box.
I don't use netscape, so I can't say what, but I've got the History in my Firefox set at one day (IE works this way, too) so that the links return to the unlooked at color after a day. If I set it at zero days they turn back right away. Upside is, if somebady else looks at this box they don't see where I've been.
I've loaded FF on the PCs at work for that same reason. The company's IE won't let us access Internet Options and even if you laboriously delete each item from History there's no way to clear the drop down on the Address Bar.
Not that I'd go anywhere bad, but they even think ytmag is a no-no.
Wm
