Re: McCormick 120 Disk--Need parts info
Posted by El Toro on January 23, 2006 at 13:50:31 from (64.12.116.65):
In Reply to: McCormick 120 Disk--Need parts info posted by Super A on January 23, 2006 at 07:14:59:
You should contact your local Case/IH dealer and see if they have their parts manual on that disk.
They may even fax or mail you a copy. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
