Farmall Tractors Discussion Board
Re: Farmall 140 Main Seal
Posted by Jim Becker on January 05, 2000 at 18:26:21 from (209.30.171.74):
In Reply to: Farmall 140 Main Seal posted by Dewey on January 05, 2000 at 17:45:03:
No, your biggest problem will be pulling the crankshaft pulley. Pull the whole front end off. Then use a REAL GOOD puller, using a bearing splitter to get good support behind the pulley, otherwise you will probably break the pulley. Install the new seal into the front cover and leave the cover loose until the pulley is in place. Then tighten the cover (This centers the seal.).
Post A Followup
: Re: Re: Farmall 140 Main Seal
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
