Re: Ya Think?
Posted by Allan in NE on January 23, 2006 at 16:51:46 from (148.78.243.26):
In Reply to: Re: Ya Think? posted by Larry-Tx on January 23, 2006 at 16:34:23:
Hi Larry,
I've always wanted one of these jokers; never could afford 'em 'til they started gettin' too darned old and "out of fashion" fer the big boys. :>)
Since I always have stacked 11 bales to a stack, this thing ought to do the trick perfect for me, I'm thinkin'.
So, they just aren't that tough to handle? I've just never seen anything smaller than a 1066 in front of 'em, is all. :>)
One more question: I would imagine that you have to have the PTO completely shut off to reverse the chain direction with the hydraulics? It would probably tear things up if you had both going at the same time?
Allan
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
