Re: BAD LOOKIN POINTS
Posted by old on January 23, 2006 at 17:50:00 from (207.69.137.34):
In Reply to: BAD LOOKIN POINTS posted by Glenn in OH on January 23, 2006 at 17:35:36:
12 volts on a 6 volt coil make the coil hot and burns points out fast. Yep you need a ballast resistor. I always use one made for an early dodge truck say around a 1970 or so. Costs about $5-10 and will save you $$ down the road in points and coils
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
