Re: Rear wheel bearing turning in housing
Posted by Janicholson on January 24, 2006 at 06:13:33 from (199.17.6.175):
In Reply to: Rear wheel bearing turning in housing posted by bbwhite1 on January 24, 2006 at 05:56:46:
In my opinion (without seat of the pants feel for the tractors action) a bearing will not produce "LOST MOTION". The shafts and gears in the powertrain are solid (or supposed to be). If a keway or splines, or drive coupling was allowing several degrees of rotation, hesitation would be noticable. I hope it is simple. Removing a cover, or even a plug might allow viewing teeth that (with one rear wheel in the air) would allow hand moving parts to find the looseness. Good luck,
JimN
