Farmall Tractors Discussion Board
Re: no gas to cylindrs
Posted by Rick on January 05, 2000 at 19:33:42 from (208.157.191.253):
In Reply to: no gas to cylindrs posted by tony fournier on January 05, 2000 at 19:01:04:
Are you sure you got spark to the plugs.Has this tractor sat for along time if so you may need to give it a pull or use a belt to get oil back up around the rings to get your compression back.
Post A Followup
: Re: Re: no gas to cylindrs
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
