Re: M running rough, need suggestions. Long.
Posted by old on January 24, 2006 at 09:42:53 from (207.69.137.15):
In Reply to: M running rough, need suggestions. Long. posted by unioncreek on January 24, 2006 at 07:52:16:
In line fuel filter cause problems on gravity feed fuel systems. In line filters are made for fuel systems with a fuel pump and your tractor doesn't have a fuel pump. I'd throw it away and see if that helps, doesn't take much to clog them to the point that they don't work on a tractor and cause you not to get enough fuel to the carb.
