Re: Rear wheel bearing turning in housing
Posted by Janicholson on January 24, 2006 at 11:28:59 from (199.17.6.175):
In Reply to: Re: Rear wheel bearing turning in housing posted by bbwhite1 on January 24, 2006 at 10:50:13:
If you are feeling internal movement without axle movement, there is a problem. Lifting an axle and turning a tire back and forth while looking at the gears through a plug, or access plate, will tell you whether it is in the differential, or trans/clutch.
I believe there should be less than 4" of tire rotation before all normal slack and gear backlash is taken up. If it like 10" or more, there is (In my opinion issues that will cost less to fix now than when it is broken beyond what is worn now.
Just my opinion,
JimN
