Re: BAD LOOKIN POINTS
Posted by Mr. Farmall on January 24, 2006 at 14:55:09 from (205.188.116.133):
In Reply to: BAD LOOKIN POINTS posted by Glenn in OH on January 23, 2006 at 17:35:36:
Get yourself a Pertronix ignition kit and then you will not have to mess around with points again. That is what I did for my Farmall A.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
