Mc Cormick
Posted by Ol Chief on January 24, 2006 at 17:58:10 from (69.91.92.207):
Have had constant problems with excessive hydraulic pressure.Found a broken spring in the regulating valve.I replaced with new factory spring and renewed the o-rings. It worked OK for just a few days but now is back to the same problem.The excessive pressure is raising the relief valve and overloading the pump and engine.What is the cure and is this a common problem?It is also causing leaks everywhere.
