Re: Farmall 706 rear end noise
Posted by the tractor vet on January 24, 2006 at 19:30:12 from (4.124.86.135):
In Reply to: Farmall 706 rear end noise posted by Stroked550 on January 24, 2006 at 17:21:54:
Are you sure that it is comming from the right rear and not telagraffen from the speed trans , if it is in the right side then check the bull pinion bearings and also see if ya got oil in the right bull gear as the bull gears do not lube from the rearend they have a fill plug on each side and a drain plug each . Now if it had ever been down then there may be a chance that they may have drilled a couple holes down in the bottom of the rearend housing to allow it to lube thru but not likey . If and when i have to pull the axel housings i will drill them
