Farmall Tractors Discussion Board
Re: Painting International red over yellow
Posted by doug nickerson on January 06, 2000 at 04:18:32 from (209.240.200.14):
In Reply to: Painting International red over yellow posted by Bob D on January 05, 2000 at 15:24:06:
the best and probably only way to paint red on yellow is to follow these steps.
1- first degrease and clean
2- sand and scuff the whole tractor or parts if it is apart
3- get a good primer sealer(gray is the best for this situation) and shoot a good couple coats on it. or until the yellow isn't bleeding thru
4- select the red you are going to use and shoot it until desired finish is reached.
your other option is to have all of the paint removed from the tractor. this is easy if it is apart, you can have everything sand blasted or glass beaded. glass beading gives a smoother finish when done.
good luck. you have some work ahead of you.
Post A Followup
: Re: Re: Painting International red over yellow
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
