Re: Regular Serial #
Posted by Mike Androvich on January 25, 2006 at 15:49:02 from (69.171.91.21):
In Reply to: Re: Regular Serial # posted by Milton on January 25, 2006 at 07:39:29:
Milton, I am afraid that your advice is not correct. Cowman has it right. The frame stamped serial numbers were in front of the radiator on the left rail for 1929 and older (thereabouts), and in between the clutch housing and the tranny (like the F-20s) for the later tractors.
