Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: Re: starting on gas switching to diesel
Posted by Rich B on January 06, 2000 at 04:53:53 from (156.46.71.223):
In Reply to: Re: Re: Re: Re: Re: starting on gas switching to diesel posted by Bob M on January 03, 2000 at 04:24:38:
It is very important to cool down these engines before shutting down also to drain the sump on the diesel injection pump after every use it has a drain on it, as it does fill up with diesel fuel. when that happens it will pump the crankcase full of diesel fuel goodbye bearings.The fuel pump has a packing and it isn't the best and will let fuel leak into injector pump sump. I leave my drain open all the time.This motor is very fuel eff lot cheaper to run then the gas,I have one with 22000 hours and just a valve job on it.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: starting on gas switching to diesel
