Re: High compression pistons still available anywh
Posted by ChadS on January 25, 2006 at 18:37:19 from (66.228.96.173):
In Reply to: Re: High compression pistons still available anywh posted by REDEYE on January 25, 2006 at 15:20:33:
Tisco is the red power kits. seen compression as high as 170 out of them,, but the head was shaved,, Chad
