Re: Farmall A wiring harnass????
Posted by Peabody on January 25, 2006 at 20:22:31 from (205.188.116.133):
In Reply to: Farmall A wiring harnass???? posted by Jim in Michigan on January 25, 2006 at 19:12:32:
Yeah, Brillman is who I would recommend if you just HAVE to buy one. But they are horribly expensive. Farmall wiring harnesses are really simple and a LOT cheaper to make yourself. Even by buying the stock wire from Brillman. Bob M has the wiring diagrams. If you've got any mechanical/common sense, I would make my own and save several tens (if not almost hundreds) of dollars.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
