Re: Farmall A wiring harnass????
Posted by Hugh MacKay on January 26, 2006 at 02:48:23 from (216.208.58.120):
In Reply to: Farmall A wiring harnass???? posted by Jim in Michigan on January 25, 2006 at 19:12:32:
Jim: Farmall wiring harnass at least pre 1958, are really quite simple to make up. The original IH operators manual for each tractor has an excellent diagram. Between that and Bob M's diagrams, I was able to put two of these together quite quickly. IH don't give you information on wire size, Bob does and he also gives good instruction if changing to an alternator. In his article, Bob also gives a lot of good advice. Took me longer to round up the materials, than do the actual wiring, and I had to go less than 5 miles for those.
