Re: Starter Solenoid - 400D
Posted by Bob M on January 26, 2006 at 07:37:28 from (151.190.254.108):
In Reply to: Starter Solenoid - 400D posted by Farmall Frank on January 26, 2006 at 06:57:19:
Frank - You are correct: BOTH large posts should be isolated from ground (ie. the solenoid shell). So it sounds like you've got a messed up solenoid!
Ohmmeter readings for good solenoid should be as below -
At rest:
Heavy post to heavy post: (infinity)
Both heavy posts to ground: (infinity)
Small right post to ground: several ohms
Small left post to ground: (infinity)
Soleniod energized (12 volts applied to the small right post):
Heavy post to heavy post: 0
...and 12 volts to ground should appear at the small left post.
