Re: Farmall A wiring harnass????
Posted by El Toro on January 26, 2006 at 09:43:07 from (205.188.116.133):
In Reply to: Farmall A wiring harnass???? posted by Jim in Michigan on January 25, 2006 at 19:12:32:
I think the ones that recommended you make your
wins hands down. Home Depot has stranded wire too. You need to identify each wire as to where it was installed before you remove them. Make the wires a little longer. I would use use the spades that you solder on. Take a small sample of wire with you to get the correct gauge. Hal
