Re: Looking at a 350 Utility..
Posted by TDK on January 26, 2006 at 21:03:08 from (152.163.100.65):
In Reply to: Looking at a 350 Utility.. posted by BobG in VA on January 26, 2006 at 06:04:19:
Bob, Just found your post about the 350U. "Chschafer is right, if it hasn't seen a lot of loader work or been abused, then the steering box is probably OK. Determine how much of the steering play is actually in gearbox. A 1/4 turn in box can usually be fixed. If it has manual steering,there's only two seals in it. One each on the steering shaft arms. Leaks here is easily seen. On a power steering box they can leak at above seals as well as at the seal underneath the steering wheel. All of the above is an easy fix. Both boxes have a welsh plug in the bottom that can leak, which will require removal of gearbox. Could also be a hyd. fitting,line, cylinder on the box. If it has independent pto the actuating handle will be on the right of driver, between hyd, valves and fender. If regular pto the handle will be a small rod behind the seat, between the rockshaft and the chassis. The brakes can usually be fixed by removing and cleaning. Sometimes you will have to replace balls, springs and disks. If, after removing them, the inside of housing shows signs of oil, then the bull pinion seal needs replaced. You may already be familiar with this if you've encountered the same problem on the SC or 130, as the 350 brakes are basically the same except larger. The 300/350's are good tractors for their designed purpose. Great for small farm, easier to get in to tight places or low sheds than a Farmall.
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
