Farmall Tractors Discussion Board
Re: no gas to cylindrs
Posted by HR on January 06, 2000 at 09:39:49 from (207.115.63.24):
In Reply to: no gas to cylindrs posted by tony fournier on January 05, 2000 at 19:01:04:
Tony: Tim said his will NOT start at +30 degrees and that is way too warm to blame just the cold for not starting. There was a couple hundred thousand model C's (regular & Super) and IHC didn't sell poor starting tractors even with 6 volts. I'll guess that both of you need to do some more general tune-up work. Everything related to starting should be examined (not just looked at) to see if its doing the job it was intended to do. Don't trust battery cables just because they "look good" but rather measure the voltage at the starter while under load..etc That sort of "detailed" exam need to be done sometimes on these old tractors every 40 years or so.. Our Farmall always started even at minus 25 degrees below..so 30 degrees above is no problem..if you do a proper and COMPLETE tune-up..best of luck in your tune up..harvey
Post A Followup
: Re: Re: no gas to cylindrs
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
