Re: Clutch arm extension?
Posted by chadd on January 27, 2006 at 10:07:55 from (155.92.30.128):
In Reply to: Re: Clutch arm extension? posted by the tractor vet on January 27, 2006 at 09:34:07:
Thanks for the reply. I was also wondering, will that affect the free play of the clutch pedal? It seems to have a lot (about an inch) more free play at the platform than what my service manual recommends. The throw-out bearing is good and the clutch disc has been in a year. I adjusted it the first time with a gap gauge between the clutch fingers and throw out bearing. Should I continue doing this instead of using the pedal measurement?
