Re: 101 combine
Posted by chadd on January 27, 2006 at 10:18:53 from (155.92.30.128):
In Reply to: 101 combine posted by Sam in Mo on January 27, 2006 at 08:52:17:
It might be a C-221, which would fit a 460 or 606. The 101 combine and those tractors share the same diesel engine, so I would assume that they would share gas engines too, but that may not be the case. It could also be an old IH truck engine. Also, there are two types of 221's, one with sleeves and one without. Some combines got the non-sleeved motor, so if it is a C-221, you may want to consider putting some sleeves in it when doing the motor swap.
