Re: Early 560's what was the rear end problem?
Posted by Steve in Tex on January 27, 2006 at 11:54:09 from (207.7.221.24):
In Reply to: Early 560's what was the rear end problem? posted by Ronald on January 26, 2006 at 19:11:36:
Ronald, An article by Jim Rose in Red Power Magazine, Mar- April 02 detailed the history & solving of rear-end failures of IH 5 speed tractors. The 560 had the most failures because it was the biggest tractor and subjected to much more stress in row crop farming. The final answer to address the problem was changing the inside axle bearings with cylindrical roller type bearings.
For the 560, the bearing no. is Case/IH part #376215R91. My own 560 has this revised bearing, but there is no triangle marked on the serial tag.
