Re: Early 560's what was the rear end problem?
Posted by Dave Slater on January 27, 2006 at 15:31:56 from (152.163.100.65):
In Reply to: Early 560's what was the rear end problem? posted by Ronald on January 26, 2006 at 19:11:36:
When they finished making changes to later tractors they ended up with differential carrier and support bearings change,bull pinion shafts,bearings and cage change,bull gears changed
,axle bearings changed, and return oil pipe from hydraulics changed to dump more oil in differential ring gear area.May have forgot something.
