Re: Farmall Heads casting #s ground down
Posted by Dave Slater on January 27, 2006 at 15:40:49 from (152.163.100.65):
In Reply to: Farmall Heads casting #s ground down posted by Jerryh on January 27, 2006 at 15:25:30:
Don't know the reason,but a possibilty is that seems like a place they crack if the antifreeze gets to weak in cold weather.See some repaired there.Sometimes find # stamped on right rear side
of head.
