Re: super a timing marks
Posted by KEB on January 28, 2006 at 14:09:17 from (192.31.106.34):
In Reply to: Re: super a timing marks posted by Andy Martin on January 28, 2006 at 10:33:54:
Here"s the procedure to set static timing. Works on any engine with points (except magnetos). 1. If you"ve taken the distributor off, verify that the rotor points to #1 terminal when #1 cylinder is at TDC. 2. Set the point gap, as gap affects timing. 3. Set the distributor to the full retarded position (turn it to the end of the adjust range in the direction the rotor turns). 4. Crank the engine around until the timing marks line up (doesn"t matter whether or not #1 is on compression at this point). If you go past the timing mark, go all the way around again. This is to ensure that you"ve taken up any slack in the drive gears/chain so it doesn"t affect timing. 5. Connect a test light from the low (points) side of the coil to ground (a meter works also but a test light is easier). Leave the distributor cap off to make sure the engine can"t fire. 6. Turn on the ignition. The test light should be off (shorted to ground by the points). 7. Slowly turn the distributor in the advance (opposite the way the rotor turns) direction until the test light comes on, which indicates the points have opened. 8. Turn off the ignition & put it all back together. This procedure is a lot more accurate than eyeballing the points to see when they open, and just as easy. Keith
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
