Re: I want to start my 300.
Posted by old on January 28, 2006 at 14:57:26 from (207.69.137.27):
In Reply to: I want to start my 300. posted by Kelly C on January 28, 2006 at 12:42:51:
You can run it safely for about 5-10 mintues but thats the max as far as the 10 minutes. That is also an old trick to loosen stuck rings in an engine that has set for a long time. But if you start to see steam comeing out the top hose area its time to shut it off.
