H magneto timing problem
Posted by mikeinWA on January 28, 2006 at 15:19:01 from (69.29.198.25):
I have a 1940 H. It has jumped time twice. Twice I have switched the plug wires 180 degrees, and twice that solved the problem; the first time for almost a year and the second for about a month. Now it did it again and no matter what I do I cannot get the timing within more than 40 degrees following the IT manual. The magneto seems functional (it is actually a battery ignition with an external coil), I have gone so far as to pull the timing cover and cam gear and everything looks good. What is causing this???? Any help will be greatly appreciated.
