Re: No luck w/300 so far.
Posted by Janicholson on January 28, 2006 at 16:41:09 from (66.173.50.93):
In Reply to: Re: No luck w/300 so far. posted by PAULIH300 on January 28, 2006 at 16:10:52:
Give it a compression check, if there are stuck valves, or (fate be the worst case) valve timing issues, it will show up.
JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
