Re: No luck w/300 so far.
Posted by old on January 28, 2006 at 19:35:35 from (207.69.138.141):
In Reply to: Re: No luck w/300 so far. posted by Kelly C on January 28, 2006 at 16:56:17:
Yep thats why you need to go to the bascis. So many things could be worng or it could just be kicking your but and is ready to run but you can't turn it over fast engough to get it to run. seen more then once that pulling is all it need to start first time every time from then on
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
