Re: No luck w/300 so far.
Posted by El Toro on January 29, 2006 at 09:59:25 from (64.12.116.65):
In Reply to: No luck w/300 so far. posted by Kelly C on January 28, 2006 at 16:02:17:
To see if your valve timing is correct bring No1 piston up on the compression stroke to TDC. Both valves on that cylinder should be closed. The plug wires in correct firing order. 1-5-3-6-2-4.
Hal
