Re: Farmall H - No Power
Posted by DigDugNC on January 29, 2006 at 11:22:22 from (148.134.37.2):
In Reply to: Farmall H - No Power posted by fqrq on January 27, 2006 at 15:21:43:
You said carb just rebuilt! You are not getting enough fuel. I went through this same problem on a "M" that wasn't running because trash/rust from the tank got to the carb. After rebuild, residue trash in the gas line (I forgot to clean out) caused the main needle in the carb to clog again, causing the tractor to run o.k. at idle and bogg down or die under high rpm or a load. Took carb apart recleaned and presto runs fine now. Also follow Wayne Swensons post to get the "sweet spot"
