Re: Straight Pipe
Posted by Randy-IA on January 29, 2006 at 14:17:51 from (207.177.83.5):
In Reply to: Straight Pipe posted by Dellbertt on January 29, 2006 at 13:08:40:
No fact's here but I read an articale once that dismissed that as a old wives tale to a point . There does need to be some length of exhuast pipe but I don't remember if it was for the reason's you mentioned or not . Just think about those high dollar race engines at a straight track , they aren't going to trash a set of $30,000 heads and they run staight pipes with exotic fuel . I've run my Harley for 20 years ( 84 FXST ) with 21" gooseneck style straight pipes with no adverse effects except some hearing loss in my right ear . Still have the same pipes on it though I don't ride it anymore - no time . I've had those pipes glowing bright red on some long high speed runs with misadjusted timing ( I took the e-box out about 2 days after I bought the bike new and put in points ). Needless to say there isn't much chrome left on them these day's ...Randy
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
