Re: F-12 Torque Specs Valve Clearances
Posted by Dave Allgire on January 29, 2006 at 17:39:48 from (24.207.231.195):
In Reply to: F-12 Torque Specs Valve Clearances posted by skycarp on January 27, 2006 at 14:29:22:
I own both an F12 and F-14. I found the heads to be torqued at 90 ft. lbs on disassembly. I can not find any literature to support that. But, I have not experienced any leaks or problems by torquing them to this value. The valves are to be adjusted to .013H (hot) that's for both intake and exhaust. Hope this helps
