Re: Farmall H lift-All use long?
Posted by RustyFarmall on January 29, 2006 at 21:44:55 from (199.120.81.239):
In Reply to: Re: Farmall H lift-All use long? posted by Boyd G on January 29, 2006 at 16:05:14:
That is correct. In fact, the use of the dipstick is over-rated, most of the time you will be better off to ignore the dipstick. If the loader or other implement will not lift high enough, add more oil to the system. If you add too much oil, the excess will come out of the fill cap, which does tend to make a mess, but nothing you can't clean up.
